Finishing pvc panel ends
13 Jul 2004
Hi, i want to fit half a bathroom wall with pvc panels , i only want to go aprox half way. I will be using 5mm batons to attatch the panels . I have purchased the plinth(skirting ) to match and also a dado rail ,the problem is i am certain i cannot use a dado rail as the panels will be 5mm away from the wall at the top and bottom . The dado rail and plinth will have to go back as i dont see how i can use these with the use of battons , could anyone please suggest a alternative . The panels are 100mm wide and aprox 1100mm high and are white. Thanks
try some plastic trim what window fitters use, D section, its app. 20mm wide, it comes in 5 meter lenghs, and only costs a few pounds
I take it you cannot get that from the local DIY superstore . Any sugestions as to were i might purchase some . Thanks .
some of the larger diy stores may stock it, or try a local upvc window firm or plastics warehouse
