hi got called to a hotel other day regarding a fire alarm sounder bell old school type 24v. maintenance guy had removed the wire and put them in to terminal blocks brown to brown blue to blue. guy said they had a revenonations done few month ago. when testing alarm sounder failed to ring this test (had been ringing when tested prior). i put the bell back together browns to + blue to - bell then immediately rang (not in test mode at this point). one new smoke detector head had also been installed (after renovations) as water damage or debris had caused the alarm to fault often. question why is the bell sounding when it should not be
could a incorrect head cause the fault to occur
need some ideas as i could not performs test 1st visit due to a wedding going on and i only have a 30 minute window tomorrow between appointments and conferences etc
