sure do.
with non addressable detectors they have a light that latches on when it activates, so if its a false alarm you look for the one with the light lit.
You may notice in your travles that you will see some rooms with a led outside on a blanking plate, this is usually connectd to the detector so you know its this one that has gone off, and ideally you feel the door first to find out is it hot, if it is you dont open it (there is a fire the other side)
addressable detectors on the other hand are easier.(in theory)
you open the box of the brand new detector and say "hello mr detector, you are detector number 1" the detector then replies and says "ok"
there, you have now addressed the detector
ok, so you dont actually speak to them, but you do change its switches to set its address, or connect it to a programmer and address it.
(depends on what brand)
addressable detectors send messages to the panel doewn the cable, i.e "its a lovely day, and no smoke here" or "Oh sh** there is a fire here" or even "I am a bit dusty, i need a clean" (it really does)
well thats what the signals mean, its not what they really send, but that is what the panel interprets them as.
The problem with addressable detectors is this
1 - 2 -3 -4 - 5- 6- 7
new install, all detectors in a line
now more are added
......... I
........ 22-23-47 (ignore the dots)
you then get a fault on detector number 23
where the hell is number 23 if they only have 10 detectors?
23 happens to be next in line to 22, which in turn is "looped" from 5 but you cant see that
ideally a drawing for all detecor addresses should be on site,
now you could say take them all out and look at the addresses, one problem, you are in a warehouse that is 30 feet tall and you cant really see them let alone reach them.
then you can have sounders that if they are just say a bell, will pulse to indicate FIRE in the building, and then it changes to continious to say its in your area evacuate.
you can also get talking sounders
clicky (its a genuine talking sounder)
then you have to consider deaf people, so you install strobe lights
then it goes into bringing lifts to the ground floor, closing doors, etc etc
