Fire Board for building control
19 Nov 2013
Essex
I'm in the middle of a garage conversion, my garage is joined to my neighbours garage, after putting a new roof on my side i have raised the height by 6-8 inches(slight pitch). Now the problem i have is the gap between the neighbours roof and mine.The centre wall is 6" wide block single skin.which has a timber plate on. Building control said to build up with C16 timbers, fit a cement fire board externally, fill any gaps with fire retardent intumastic sealant insulate then internally line with plasterboard and skim to give at least 1 hour fire gap between properties..,
Where can i find this cement fire board? is this the tile backer stuff or is there a more specific board for this application?
Sorry if this is rambling on but i need to get it sorted this week as its cold in there now.
Andy
I used some for a register plate above a log burner, its thinner and much harder then plasterboard. Its also thinner and harder then the cementatious tileing board used around showers which has the glassfibre reinforcement in it. And it ruins saws, use a disc cutter. Could be this stuff :- www.jameshardie.co.uk/images/.../hardiebacker-multifuel-leaflet.pdf , I just went into my builders merchants and just aked for some.
Frank
Standard Hardiebacker can't be used externally.
Supalux is the most well-known, but it's expensive. A cheaper product, Masterboard will do, but only for semi-exposed areas.
Have a search for Magnesium Oxide boards, such as Econicboard or Enviroboard, or Versaboard / Versafire. These are cheap
You'll need 60 minutes fire resistance bear that in mind for selecting thickness
Some here to get you going www.euroform.co.uk/versafire_what_is.shtml
Thanks for that, my local Travis Perkins stocks masterboard, it only has 6mm thick which offers 30 mins fire rating, alond with my
insulation, intumastic sealant, plasterboard and skim this should give me the desired 60 mins ? or am i wrong?
Andy
ahh ok thanks for that was looking at it wrong, ive found a versapanel which at 10mm offers a 60 min fire gap and is class "o" for building regs.
Think thats the stuff £70 for 2 sheets though ...
