May i ask for some help with ironmongery? In my workshop i have a steel fire door that is about to fall apart. i am going to replace it with a 1hr rated flush door. The steel door functioned in a way that it could be opened to 90 degrees then lock open, but would slam shut when pulled.
I have looked at sprung hinges and pergo closers but these would only serve to close the door, is there anything on the market that would work in the same as the ironmongery on the steel door that could be used on a flush door?
Thank you in advance
