Fire doors in hallway
29 Jul 2015
I know the regs state that fire doors are required on any door off the stairwell in a 3+ storey house. But does this include doors off the ground floor hallway even if they are a considerable distance (5+ meters) from the stairwell?
Does it also apply to an understairs cupboard? Or is it only habitable rooms?
Cheers.
You do not necessarily need fire doors on all openings into the hall - some inspectors will allow the existing (non-fire doors) to remain if all habitable rooms + kitchen + hall and landings have interlinked alarms.
It's down to risk, but some LABC inspectors slavishly follow the Approved Doc. B (which by the way is not the regs) without considering alternatives.
The concept is one of a protected escape route, not just a stairwell.
It's all doors to all habitable rooms, kitchens and garages that are off the protected escape route - ie all high risk areas. In some properties there may be a cupboard where there may be a risk of fire due to what is or is likley to be stored in it, in which case that will be included.
