Hello there, hope someone can help,
In my single storey, flat I took down a wall which separated the kitchen from the reception room to make a kitchen/living area. This new room is connected via a door to the hallway (that has two bedrooms and a bathroom off it), which in turn leads to the front door. All ground floor. Building control are asking that the door between the kitchen/reception and the hallway be fireproof. I thought that because it was ground floor and the escape route (bedroom through hallway to front door) doesn't pass through the kitchen/reception room it wouldn't need a fire door.
But anyway, if it IS required, what do I do about the large transom window above the door? Is it necessary and possible to make that fireproof as well? I can't fill it in without losing a lot of light into the hallway area. Any thoughts welcome. Property is an 1880s mansion block if that makes a difference.
