The mains powered, interlinked fire alarms in my house have started to fail so I picked up some Kidde KF1/2/3's to replace them. I couldnt find ones to match the originals and given they were interlinked, I thought it best to replace them all anyway.
The problem is the connector for the Kidde alarms is longer so it protrudes in the ceiling. Whereas the originals the connector didn't protrude past the mounting plate. As a result the sparky appears to have taken a shortcut, cut a small hole to allow the wire to pass through the ceiling, terminated with connector and then partially filled with some sort of intumescent material.
Kidde suggest using a dry lining box and most threads I've been reading suggest trying a circular dry lining box (so I can just use a hole saw, making it easier now I can't get access from above). But I can't find any fire rated circular boxes. My property is over 3 floors, so thus far all down lights/etc (even doors) I'v stuck to installing fire rated.
Any suggestions?
Any suggestions?
