Evening all! First post, so go easy
I've just moved into an Edwardian property which has a working clay back fireplace & have removed the surrounding out-of-keeping 1970s blockwork. The main issue is I've only been left with 170mm depth of fireplace. The original grate which sits on top is 280mm deep. Is the remaining overlap of grate just meant to sit on the (granite) hearth as pictured below?
I was planning to dot & dab the granite hearth down onto the constuctional hearth below using drywall adhesive. I was then planning to render the existing brickwork & tile over. Finally, I was planning to fit a large wooden surround. Does all of that sound feasible?
• Also, is fire cement an appropriate product to use for rendering?
• Will regular tiles, adhesive & grout suffice? Or are there specialist fire resistant products I should be using?
• Any other recommendations?
In case it helps, below is how it currently looks. Thanks in advance, Ben
