fireplace rendering
21 Jan 2009
Sussex
hello,
i am going to have a woodburner installed and have a fireplace recess back to brick
can i use render beads on the external angles to work from? not sure due to heat
and i am going to use 6-1-1 sand/lime/opc and the 7-1-1
do i ha\/e to use the mesh under this or will it be ok, its normal bricks
and the outside will be skimmed as its a normal breast, is it ok to use a thin coat stop bead around the opening and use multifinish as normal
Thanks alot
KP
Yes you can use render beads. Before you put the scrach coat on brush on a coat of watered down pva to help stop suction. The mix i use is 4-1-1 scrach coat 5-1-1 finish coat with washed plastering sand. There is no need to use mesh if the brick work is ok and no big voids in it. You can use thin coat stop beads and multi finish on the face side i.e. the breast. Hope this helps you. :) S/S
