First fix roof framing, which saw?
11 Apr 2006
Berkshire
Up until now I've been using a dewalt chop saw that has 50/60 degree bevel/mitre so there's nothing it can't do in terms of making an accurate compound cut.
It's pretty back breaking though - having to move every rafter/joist to position, flipping around, cutting again etc. This autumn I'm doing a roof with two valleys and I'm wondering if I should get a battery circular saw instead so that I just run around the stack of wood putting the cuts on either end wherever the merchants dumped them. Is it realistic given the plunge depth needed at a 45 degree bevel?
Which model saw do you guys use? Do you use a simple circular saw for the easy straight cuts then something more fancy for the more demanding valley/rafters?
Back breaking? You just want a new saw don't you. :rolleyes:
It will need to be a big, heavy, awkward mofo to do those cuts. Watch that old back.
Couple of Jack saws for a tenner.
Back breaking?
Yes. The rafters are manoeuvred at waist height. You've obviously not had to cut a roof Woods. A decent size one is back breaking and knackering to cut.
I use a big DeWalt (mounted on a fold-away ally bench) and a corded Makita. Neither are particularly wieldy but both have ample power.
What? It's a plank of wood, and you just run the saw across it. :confused:
Wait until the OP starts laying the patio slabs, then he'll know what back breaking is.
Ahh, you deffo have never cut a roof.(y)
I find it mush easier laying slabs than cutting rafters and I do loads of both.
As I said, its the height of the workpiece. The tiring bit (on your trunk muscles) is the constant shifting/positioning when lining up the blade with the lines. Each rafter can involve quite a few cuts too. The length of the timbers (swinging and switching) has a knackering effect, even though they weigh less than a more compact but heavier object.
Yes it's this in essence. I'm starting to think I should be moving the saw rather than moving the piece. You seem to do a bit of both. The next roof is made of 6M length 175x50s and there a good 50 of them so I'll buy a new saw then chuck it back on ebay afterwards if its worth doing.
