I am about to run my first fix Ring main in a new extension first floor, and was wondering if their is a minimum distance that the cable should run from the joist ends between ground floor and first floor? (i.e. where joist and wall meet)
I know the depth and maximum hole size but the distance from joist end I could not source? The joists are 10x2 x 4.5meters long.
The ring will run from one bedroom, under a en-suit and back up vertically into the next bedroom to continue the ring. The stud work and first fix plumbing is already in the en-suite within building regs area and the bath will be postioned to the wall that I would be running the ring below.
I maybe going about this the wrong? It be easier going through the roofspace?
Regards,
Bob
Regards,
Bob
