Hey if first fixing a new build house in copper. Whats the best way to first fix for the rads, in 15mm copper pipe and coming up through the floor to the rads? I've usualy done it in plastic bringing 15mm copper up through the floor, the plastic pipe work giving a bit of play if the dot and dab is abit larger then normal the pipes will still line up. Copper won't allow for this.
