Hi folks.
Long time lurker, first time poster here. I've finally signed up after me and the mrs bought our first house, moved in and settled now around 6 months with our 2 year old, We're based in Northern Ireland. House was built in 60s and garage was added later.
Never really done any DIY before and never really had to until now. I am a COMPELTE beginner but have learned and tried to much myself the past few months, never anyone to show me these kind of things other than my mum.
Long story short we were a bit niave buying our first home, kind of knew the people we bought it off and it was left in a state which wasn't exactly great for us with a child, first day we walked in the shower fell off the wall... after getting a lend of some money its pretty decent now and just some normal things to do to it as we go a long over the years, new floors that type of thing just to do it up to how we like.
I am actually here today out of a place of anxiety, the house comes with decently sized detatched garage, electrics and heated which is nice as the boiler has been moved out there unfortuately not amazingly done but it all works nonetheless.
The problem is I've developed a sort of anxiety about the garage and its condition due to discovering problem after problem with it, all basicaally coming from the roof and it's also funnily enough where I'm getting my confidence to do my DIY repairs from at the same time. I just want everything in the house to be problem free but I guess that will never happen
So a small list of things I'd like to do based on what I feel I can do.
-Roof ridge an verge needs rebed and pointed, previous owner stuffed it with newspaper.. I know! I didn't even know what a ridge was before I bought the house,looked into dry ridge and dry verge but don't feel I want to attempt this yet and feel a bit more happier rebedding these for now and looking into doing dry versions in a couple years.
-The garage door was replaced with this window type thing and is letting water underneath it on windy days, I originally filled it with expanding foam but I've scraped this out today and applied all weather sealant as best I can and hope this does the trick for now
-The garage has a room built into it which I'd like to remove in future, unfortuantely the verge is letting water in and the wood behind the soffit has started to rot, i pulled this out and cemented it up to cover up the gap, but you can see in the picture its started to get damp down the wall. - A Bird has made its nest ontop of the roof in the garage up in the rafters, its going in and out of the hole in the verge, I believe I'm not allowed to remove this for now but it's going to be a nightmare to get it out.
-I'm a little worried about the brickwork inside, someone told me it looks fine the brickie just didn't make it look nice, but it's still probably looks the sdame as the day it was built.
My major concerns
-I've had a roofer come look over the roof and basically they quoted me about £1500 to install dryverge/ridge and refelt it but I simply cannot afford this, they've told me the overhang is too short, I also asked a guttering guy to come look, he hasn't been yet but said to fix the overhang it would be pricey and espeically if the barge? board is rotting underneath, to redo it all. So is it something I need?
-If you look up into the rafters some of the felt is ripped, I'm not going to replace this but some of the battens for the tiles aren't great and one looks to be almost snapped in the middle, I'm wondering if its just wet? I'm going to lift some tiles and replace this myself and nail it back to the rafters.
-Guttering is fine on the garage I've repaired some leaks in the join, but the drainage for it is non exsistent, it just goes down the garden path ffs, what can I do about this? my garden is concrete so I don't feel like digging it up I'm sure its major work? I would install a drain myself or a soakaway is it? but I don't know where I would direct the pipe to, down the bottom of the garden? Thee house behind me has a massive garden and our gardens back on to each other but there is a strip of unused land between us
I'm fairly sure thats it, I've included as many pictures as I can and tried to order them, I would welcome ANY help at all to get these project done, cosmetic wise I know the pebble dash render isnt great but first priority is to get it water tight and then I can get it all fixed up inside.
Also I do have a major major worry, If I lift the ridge tile I can see lots of woodlice, They are everywhere in the garage, I've put down ant killer and I find dead ones everyday, it's a lot better than it was but I'm still finding new all the time, are they coming from the roof? are they getting in soemwhere I can't see? Eventually I'd like to plaster up the garage so I don't want it crawling ith bugs, I know they can be normal but I'm thinking it's way beyond more than normal. I'm hoping they are getting in the roof and falling down as I am finding lots of their minute droppings. - Any suggestions on this?
https://ibb.co/z6CCXy4
https://ibb.co/NT3BNhJ
https://ibb.co/qg4Tm0g
https://ibb.co/FVnn77v
https://ibb.co/MPgpksH
https://ibb.co/myK7wqT
https://ibb.co/kxK29fN
https://ibb.co/TPwjny5
https://ibb.co/V9V6v6d
https://ibb.co/q908b8s
https://ibb.co/tcFBtjv
https://ibb.co/vhxLT9x
https://ibb.co/rKB1tH0
https://ibb.co/3fFvPht
https://ibb.co/DVTQ7wx
https://ibb.co/0tfM64H
https://ibb.co/YcxZ4XB
https://ibb.co/CVKHhLR
https://ibb.co/Qdg8L0t
https://ibb.co/GdTzsqn
https://ibb.co/WyyYsxN
https://ibb.co/1mrDpPg
https://ibb.co/ZVVrx9k
https://ibb.co/cQRWGDq
https://ibb.co/PjLgMs7
https://ibb.co/pf1TzjT
https://ibb.co/7v9q6Gx
https://ibb.co/m8TnZyQ
https://ibb.co/vD5txmw
https://ibb.co/qdg63G6
https://ibb.co/Svdgdj9
https://ibb.co/QjqTY3q
https://ibb.co/NKXcsbM
https://ibb.co/tDsSTQT
https://ibb.co/JzDT859
https://ibb.co/1vrmLWh
https://ibb.co/zQjPg0v
https://ibb.co/1RZVwFk
https://ibb.co/LrGMr8x
https://ibb.co/zSw10h8
https://ibb.co/HrZC5CL
https://ibb.co/tpQWty8
https://ibb.co/RS91XWC
Thanks for reading!
- Edit, the front of the garage has 2 bits of bare timber exposed also, I've been told these should be boxed off in a soffit box? Is this fairly easy to do or should I have a professional come do it?
My major concerns
Thanks for reading!
