I am buying my first house and want to have some decoration done before moving in. I only have theoretical understanding of the work, so I will have someone do the work for me. There are a few plans stopping me from getting the whole picture.
The place is around 80 sqr meters, with ground and first floors. I am planning to break this project down into two phases, first the top floor, then the ground floor (living/dining areas). Upstairs we have 3 beds and a bathroom. I want to do the bathroom and decorate the 3 beds and corridor/stairwell. I want to remove the old wallpaper and repaper and decorate, plus ceiling, plus all the woodwork, doors, skirting board need redoing.
There are two chimney breasts, one in each of the two large bedrooms from the living room and dining room respectively. I don't have a clear picture yet, one of them is inside the wardrobe (which I want to keep). The second one from the dining room is thinning up as it comes through the first floor. This is the one I want to remove to make space for a large wardrobe.
I may remove it in two phases, besides first floor needs to go first. How messy and costly is the removal job?
And to the actual decoration questions, starting with upstairs. I would like wooden floors. In what order should I plan the work if I want wooden floor and wardrobes?
Phase two, the same work will be done downstairs, except the living and dining rooms have a wall between with two door wide opening. I want to open up completely and that will probably require a support beam across. Am I right in saying that I can't go ahead with decorating and fitting wooden floors downstairs till the widening job is done first?
I understand it is all a bit ambitious and abstract, any thoughts and cost estimates would be much appreciated.
