Firstly, hi to all here!
I have just moved into my first home with my girlfriend and we are making a start on our first diy project. We are going to give the lounge an overhaul and have started by removing all skirting.
Now the skirting has been removed we want to plaster the sections missing plaster - we are doing without skirting all together.
My question is, what would be the best way to fill the gap at the bottom of all the walls where the skirting has been removed? There is a 1.5cm deep gap around the perimeter of the room and would like to know if i should use plaster board or plaster straight onto the wall?
All the plaster that was behind the skirting had to be removed as it just crumbled away. Above the height of the skirting the plaster seems sound.
All the walls that need the work are brick, so I know they will need sealing with a pva solution but other than that would like to know the best way to go about it..
thanks
Adam
thanks
Adam
