hi,
Due to build my first stud wall shortly for taking off part of a bedroom to make a space for an ensuite.
Couple of questions for starter!
1- It needs a door, so I'd get a door liner kit for ease - noticed they are suitable for studwork at either 100mm or 75mm thick.
Is 75mm too flimsy and 100mm recommended, or is 75mm generally ok?
2- it needs some insulation in between studs. Is slab insulation usually better for this (e.g. Celotex) and akso would you size it to fill the void? I noticed it's available 25/50/75/100mm etc. I will have some electrics to make room for in the void or perhaps a little pipe work for towel rad. Would you go for 50mm in that case for example?
