I currently have just a single coaxial cable going from my sky dish to the lounge connected to a face plate. The shotgun cable goes from the sky dish into the loft then into a converter (global stacker/destacker) which then sends the sky signal down the single coaxial cable into the lounge. I am suffering from a loss of channels lately on freesat and want to have sky tv in the lounge soon but don’t want the cables on outside of house.
Walls are dot and dab and going to try and attempt fishing the new webro wf-100 shotgun cable up through the walls and directly into sky dish (be done with the global stacker/destacker as well). I am thinking of using the current coaxial cable to join the shotgun cable onto and then pull this up through the wall standing in the loft. Problem is not sure if the joint will be strong enough by tying a knot so even looking into heat shrinking them together to provide a really strong joint so it doesn’t come loose half way up wall. It’s either this or fibreglass rods to do it (which I have) which could be a right faff with 4.5m to cover. Has anyone tried the first method of using a cable in the wall as your guide for the new cable?
