HI,
I'm not sure if this is a cavity wall or not. I am planning to hang a large tv above the fireplace on a bracket. The house was built in 2001, so it is likely to be a cavity wall?
There are a few holes already in the wall above the fireplace, and I have measured that the thickness of the plasterboard is 2cm, and then there is a 2cm air gap behind the plasterboard, then there is masonry.
Is this a cavity wall? If the screws that come with the bracket are longer than 4cm, then could I just drill the screws into the masonry behind the cavity gap?
What are the best rawl plugs to use?
I have previously hung a heavy mirror on the plasterboard only using strong rawl plugs but drilled in at 45 degrees.
