Fit a TRV without draining the system down
14 Mar 2008
Leicestershire
Hello
Can I fit a TRV without fully draining down the system? When I tried to remove the rad the water inside was under presure and everything got v wet. I believe my CH sys is of the conventional vented type.
Can anyone help, I really am out of my depth!!
Cheers
Jon
bung the vent / feed pipe to cause a vacuum in the system. then you can drain the rad and work on the pipes.
sorry, pluging the expension pipe did not work, the water is just squirting out if the 10mm pipe when I undo the nut. Any other suggestions??
you did plug both pipes as i stated earlyer vent/feed pipe.
no reason it shouldn't work never had one fail yet in yrs of plumbing.
sorry, I only plugged the expansion pipe (the one above the small tank in the loft) Which is the feed pipe? sorry to be a plank
cheers
Jon
