I have a window in an old house which is timber-framed and with no lintel. It's single glazed and the wood is bad anyway. I want to fit a smaller window and, as luck would have it, I've been donated a upvc window frame with 2 double-glazed windows. Nice.
The new frame is about 2 inches smaller in height and over a foot smaller in width. I reckon the height difference could be accommodated with a wood batten, but the width is more tricky.
Could I fill in the bulk of the 2 sides with two brick 'stacks' and lay a lintel across the top of the 2 stacks. If the wooden frame is removed at the top ( where, presumably, it acts as a lintel ) there would be room for a lintel, 3 or 4 inches in height.
The window is upstairs and theres only a few rows of bricks above it. I suspect a lintel would be a good idea, but also expect the thing not to collapse in the short space of time it takes fit the new one. Or should I fit one of those long steel rods in the wall above first?
Advice would be much appreciated
Regards
bruce
Regards
bruce
