Long time forum lurker looking for advice.
I've had a brick workshop built up to the wall plate in the garden. I need to keep it below 2.5m overall to avoid planning but have hit an issue when it comes to the flat roof construction.
Because the span of the roof joists is 6m I've gone for 9"x2" joists (bought and ready to fit) on the advice of various span charts. The problem is that sitting the 9x2's on the wall plate as originally planned will make the building too high. So I've been looking at cutting an L shape out of each end and sitting them on joist hangers which will be bolted to the wooden wall plate. Assuming there is enough ceiling height inside the workshop, is this acceptable?
Also could I buy two different size joist hangers to create a fall from front to back? This would mean I don't need to fit furring strips.
Thanks.
Thanks.
