Hi
I need to fit a 900mm meter box angle lintel into a single skin block wall. I was thinking that I could try fitting it without having to remove a course?
I was thinking I could drill out the mortar bed for the length of the lintel, would somehow have to clean up with bolster/old screwdriver, and then push in the lintel, wedge up to the blocks above, then pack in a semi dry mix on the bearing at each end.
Would this work? Any tips?
