Fitted laminate/real wood floor now throne want fit
15 Nov 2004
Fitted laminate/real wood floor to bathroom but toilet now want meet as 15mm to high
Can I get hold of an angled waste fittings
also if/when I get this angled pipe, do you have to seal with 'plumbers mate' or is the rubber seal alone enough
Regards and thanks
flexible pan conector from local independant plumbing merchant. There probably an association with a web site which lists members in your area.
try this http://www.bmf.org.uk/
you might have to cut the end off the existing pan connector which looks as though it is sealed into the wall.
wrap a thick strip cut from A4 paper round the pipe to give you a neat square edge to cut too.
Thanks guys, with the angled 'adapter' (whatever), is it normal to seal the pan into the tube with a sealent (like plumbers mate et-al)
Sorry, but you are a bit of a knobber aren't you? No need for extra sealing around pan connector - you need flexi or offset pan connecter.
ATB
heeelllooo cowboyplumber how the devil are you ;)
a teeny bit harsh towards lord lucan he is asking cos he is not shure
im shure you didnt mean offence cos your a good helpfull lad :LOL:
:oops:
Reckon after this week i'll have completed the house all together (with the exception of 'the throne' that is
two other ideas:
use angle grinder to take 1/4 inch off the bottom of the toilet
cut a template for the bottom of toilet and then 'notch' out the floor
cowboyplummer, you may have a mouth as foul as my outside carsies
'u bend' but I picked up the part you mentioned, installed and SORTED
Did you cut the end off the existing pan connector or did the new one push in ?
