hi do i need to drain down the radiators? im fitting a new replacement radiator upstairs and it is slightly bigger than the existing one, i might have to alter the pipework if i do this can i use solder fittings? or is compression or pushfit best? it is not a combi system it has 2x tanks in the loft and a water storage tank....cheers scott
