fitting a central heating timer
26 Nov 2003
I have a new Worcester combi boiler with no timer fitted.
All I want is a simple timing device to control the central heating. Any tips on which one I should get and how I would wire it up :?:
See this or this , instructions for wiring should be with your boiler manual. You shouls also be using a room thermostat to comply with the building regs, and you wil need building control approval unless the installation is done by a competent person.
Or you could just fit the Worcester timer,electronic or mechanical which generally just plug in,no problem.
