fitting a chrome towel rail on combi.need help asap
21 Apr 2007
hi.need some help.
need to remove old bathroom radiator,alter pipework slightly then fit chrome one.I can fit it ok.but need to know if I turn combi off,stop cock off,will water come out when I just remove the old radiator by the valve,ie not having to drain the rad?
im sure I have seen a rad off without a leak on combi before.but need advice?
cheers
You need to drain down if you need to alter pipework and refill.
Drain off point below the old rad is needed.
Check out the FAQs for info. :D
As a diyer you are best draining the system to do pipework alteration , but your right by either closing the boiler isolating valves or if they are dodgy screw down the auto air vent cap then release the pressure in system a vacum is created and you can work on it with the system full
thanks for the advice.i have seen someone turn off stopcock,then turning the power to the combi off,then remove the rad valves.didnt screw anything down.didnt want to take this chance before asking.
to drain down,do u have to turn all the rads off?
how much should come out?
cheers
