Hi there i just started using howdens for my kitchens,i'm fitting the kitchen at the moment and i cant suss out how these clips go?????i'm thinking they are some kind of stop for the doors,any help would be greatfull thanks paul
The right angle bit sits against the back of the door frame, so one screw goes into the carcass, and one into the frame. Then stick a bubble onto the face of the clip - this is your door stop. On units without frames, the door simply closes against the front of the carcass.
