S
snadge
HI
I just finished doing our kitchen first time..kitchen was from IKEA
I installed new ceiling with recessed lights, new floor, new plumbing for sink and waste, new electric sockets, new wall mounted towel rail, new extra doorway into dining room, plasterboarded all walls...and of course installed new kitchen...
with the help of many on this forum I managed to finish it - although theres just TILING left too do which we are paying someone to do simply cos i cant be arsed...
my girlfriends advice is: dont do it !!! pay someone... just cos the hassle it can cause is not worth it...
my advice will be: do it... hehe it saved us £3500 just on the kitchen installation..i shudder to think how much builder would have charged for ceiling, floor, walls, plumbing etc etc
1. ensure your walls are straight and corners (where corner units go) are exactly 90 degrees , not over or under - put the units up loose hanging off the screws and then fix them together first before securing them into the corner/walls...we had problems here as angle was greater than 90 degrees because the stud wall (that was already there) wasnt straight and caused us problem.
2. if your bathroom is above kitchen ensure theres no leaks...or even do your bathroom first if it is to be done in future as you dont want leaks coming into your new kitchen, we had problems with leaky bathroom which we fixed before we started.
3. make sure you have all the tools and materials before you start so its not months and months from payday to payday..
4. plan out your kitchen and see if you need to get electrician in to move any switches or add any new ones etc..
- she used IKEA's online kitchen planner which plans it and orders all the stuff you need, we had no problems with this.
5. make sure you have a 1.8M level of a decent brand and a smaller one for wall units... i just used a cheapo 2ft level and its caused many problems cos it wasn't exactly level..fork out for a good one so you know when its level..ITS LEVEL!
6. make provisions for a temp kitchen somewhere else in your house...we used the downstairs toilet to wash cutlery in the sink there and moved the microwave into dining room.
7. when you rip old kitchen out..get a corgi gasman in to show him where your new hob/oven is going so he can make a first fix then if needs be... nothing worse if you have worktops fitted and the gasman cant get in or under to the pipe-work (this didnt happen to us but was advised of it so passing it on)
8. install the fridge/freezer unit first OR work out how high its going to be so you know how high to install your wall units... we didnt do this and are now in process of lowering our wall units to same height as fridge/freezer unit.
we also paid someone to cut mitres on the oak worktops, although i was close to buying a router and jig myself but it was only £50 extra to hire someone to do it ...so got a pro in...took him 5 hours for 3 lengths, 2 mitres and 1 join - I cut my own sink and gas-hob out though.. your looking at a region of £150 for the worktops to be installed (for 3 anyway) - one guy try to charge us £560 haha got rid fo him
just take your time and plan everything in advance too - make sure the wife/partner is not around to nag while your working away at it - it really is quite easy, the units come with instructions.
