I am fitting a U-shaped kitchen.
The problem is that the wall at the "bottom" of the U is 286 cm
and the units to be fitted are 285 cm, so I have 10 mm spare.
The units are 570 mm deep and the worktop is 600 mm, so the overhang
is 30 mm but the doors are 24 mm thick, only 6 mm left until now.
If I bring the units in the "legs" of the U forewards ( 5 mm each side
to make up for the 10 mm spare) and the doors are closed there is only 1 mm diference between the front of the doors and the front of the worktop
and I don't think that that looks nice.
The walls are not very straight so I can't push the work top against the splash tiles either.
Does anybody has a solution for my problem?
Very much appreciated.
