I fitted my own kitchen except worktops, and done base units first and only realised that perhaps it would have made life alot easier if i had done the wall units first, as i was having to lean and drill and hang from quite far away and it was really ackward, if you do hang wall units first then make sure you get them the right heights from the finished worktop height, allow about 40mm from teh top of your base units best to draw on the wall and make sure its all perfect.
ta dave. i have started with the wall units and it has gone well. base units now in up to the dishwasher. it's a very tight fit and i have had to rejig the waste pipe behind it.
