Fitting a mirror to tiled wall
13 Feb 2006
Tyne and Wear
I want to fit a mirror to a tiled, stud wall in front of a WHB.
What's the best way to fit it ?
I haven't actually bought the mirror yet, as some come drilled, for screw fittings.
Can I fit to a partition wall, or could silicon be used to stick it to the existing wall tiles.
A similar problem ..
How to I fit a wall cabinet to a stud wall ?
thanks
You can screw using visible or invisible fixings or glue using mirror adhesive to avoid damaging the rear surface of the mirror. Is the wall tiled where cabinet is to be fixed?
