Fitting a mirror to wardrobe door
16 Oct 2007
Manchester
Probably a very simple answer to this, but how do i go about fitting a mirror to the inside of a wardrobe door?
thanks
If the door is of framed construction when you can have the mirror cut so it fits snugly between the rails and styles, then using mirror adhesive glue it in place.
You can have the mirror drilled and you can screw it to the door using mirror screws.
Or you can use these.
Don’t forget the mirror should be safety backed.
