bobbisix said:
...unconnecting the pipes on the taps and toilet. Do i cut them off and connect hose connectors or attempt to separate them from the old taps?
Not sure what the rolling eyes are intended to convey there, but, that aside, there's no definitive answer.
It depends on how similar the new positions are going to be, and also the tap types. For example, if the new basin tap is a monobloc, and the old one isn't, then you're quite likely to be using braided flexibles, so you might as well cut the existing pipes and install valves now, then remove the basin.
Depending on the age of the bath you might be using the same distance between tap centres, so these could disconnect and leave alterations 'til later.
The WC is likely to be very different, but generally it's easy to get at the connector so you could choose just to undo this.
Since you're a plumbing newbie I hope you won't mind me reminding you to always isolate (i.e. shut off) the water supply to whatever you're working on.
A word of warning. If you have 'tank-fed' water supplies to the basin, and if the head of water is low, and if you fit a monobloc tap, then check the minimum recommended pressure for use with that new tap, otherwise you might be surprised and disappointed.
