Fitting a new built-in over
26 Aug 2006
Wiltshire
I have a built-in single oven that I'd like to replace.
If I buy another single oven with (roughly) the same external dimensions will it just be a case of sliding the old one out and pushing the new one in?
Does a fitted oven come with a separate frame that it's mounted in or are they just supported by the surrounding cabinets?
Pretty much standard fit.
Some are on rails, some sit on the cabinet base.
Pull the old one out and see what you have then you can compare the new one before buying it.
If yours is fitted to a 13 amp supply and there's no cooker supply nearby you'll be stuck with a lower powered rated machine.
