fitting a room stat
2 Oct 2010
Essex
hi i have a fer falcon combi boiler and need to fit a room stat does anyone know how i go about this thanks
There is a wring diagram showing how to connect it on page 39 of the Falcon manual click here. The thermostat, (item 72 in the diagram) needs to be one that has an isolated contact (potential free).
hi thanks for the info will a danfoss rmt 24 be ok to fit and do i come off 72 with a pair of cables into the stat thanks for your help
hi sorry forgot to ask do i take link out beween 3 and 4 on item 72 thanks again
Use a twin core cable, and yes, the link will need to be removed.
If you were to use a Danfoss RMT24, in addition to the wires for the contact, you will also need a 24v supply to operate the thermostat. It would be easier to get a battery operated thermostat with just the two wires to connect. RMT type thermostats are generally seen to be old technology now, as it has an accelerator (small heater) built in to help overcome mechanical inaccuracies.
If you prefer Danfoss a RET B would be OK, use terminals 2 & 3. Other manufacturers also produce similar units. The batteries last for over 12 months and they provide a useful actual indication of the room temperature.
