Hi all! Haven't posted in this section yet! As a keen Diyer I find this forum very resourceful.
I have converted an old boiler into a solid fuel burner. As I have no problem getting scrap pieces of timber and other solid fuels I have decided that this could be the way to go to save money on oil!
However I still want to keep the oil burner I have (stanley oil fired cooker)
and add the other boiler to the system I have.
The cuurent system has been installed approximately 15 years and has no motorised valves.
There are two pipes from the range (usual flow and return) and if I want to heat the radiators the timeclock switches on a pump (located at the side of the range itself.
I would like to link the second boiler into this system as simply as possible.
I do not want to change the cylinder in the hot-press to a twin coiled one if at all possible - it is the standard single coil type.
can I take the two pipes from the new boiler and T them into the existing stanley cooker?
Probably one would heat the other as a radiator but would this do it any harm?
Would I be better fitting a motorised valve to the system to stop any back flow?
Could the new solid fuel boiler be simply controlled by a pipe stat and pump (with the pipe stat bringing on the pump when the required temperature is reached)?
Would there be any issues with air-locking the system?
Any help on the matter would be greatly appreciated!
