Fitting a Suntile to the roof
if the tile is near the verge, hip or ridge then it will probably mean removal of these elements to get at the tile.
if the tiles above the one you want to remove aren't nailed and are not located near cement fixed elements, then these will, with a push, slide up out of the way allowing you to lift off the one in question.
if the tiles are nailed then i guess you will need a slaters rip.
