When fitting an extenal fuse box, how high off the floor should it be?
Im fitting an external fuse box and isolator switch for a hot tub, 32A RCD for the tub, and a 6A RCD for patio heater lights, and a 32A isolator switch for the tub.
Im getting an electriction to do the wiring -- I'm drilling the holes in the wall etc and laying the 6mm T&E through the house to the consumer unit (not connecting it myself!) becuase i currently have all the floors up downstairs.
The external wall will have a separate RCD fuse box and an rotary isolator (both L and N switched) screwed to it, but how high off the floor should it be?
Im not doing *any* of the connections, the electriction is. Im not cutting the boxes in any way, just screwing it to the wall, and drilling a single hole in the rear for the cable (the hole will be ducted and sealed with silicone)
The box will have a small shelter over it for extra protection, but IP65 is weatherproof anyway.
