Hi. I'm new to this plumbing lark - but having done plenty of other things on my flat successfully, I am giving it a go.
I have swapped the position of my basin and bath as part of the bathroom refurb.
I have a new bath to fit. The tap is a monobloc bath shower mixer (0.1 ->2 bar from ideal standard) the tails of the hot and cold feed for the tap are 15mm according to the spec.
I am connecting to two existing 15mm hot and cold pipes (which originally went to the basin )
What hardware do I need to connect the tap tails to the 15mm copper pipe?
People seem to suggest using a braided flexible connector with compression fittings is best?
I have looked at screwfix and i can only find the following items. Are they suitable?
1.
Flexible Tap Connectors 15mm X 1/2 . 300mm. Stainless Steel braid. 15 bar working pressure.
http://www.screwfix.com/app/sfd/cat/pro.jsp;jsessionid=BCH4WWTN01NYDCJO2C4CJ0Q?id=13143&ts=15650
THIS HAS THE RIGHT DIAMETER - BUT IS IT SAYING ITS A HALF INCH CONNECTOR AT ONE END?
2.
Flex Tap Conn C/W Valve 15*1/2 . 300mm long. Complete with isolating valve. Stainless Steel braid. 15 bar working pressure.
http://www.screwfix.com/app/sfd/cat/pro.jsp;jsessionid=BCH4WWTN01NYDCJO2C4CJ0Q?id=18417&ts=15650
IS THE ISOLATOR WORTHWHILE FOR maintenance?
WILL THE ISOLATOR REDUCE THE FLOW?
3.
Flex Tap Conn 15mmx3/4"x300mm. 300mm. Stainless Steel braid. 15bar working pressure.
http://www.screwfix.com/app/sfd/cat/pro.jsp;jsessionid=BCH4WWTN01NYDCJO2C4CJ0Q?id=77154&ts=15650
THIS HAS THE RIGHT DIAMETER - BUT IS IT SAYING ITS A 3/4 INCH CONNECTOR AT ONE END?
IS THERE NO SUCH THING AS A 15MM TO 15MM FLEXIBLE HOSE?
IF NOT - DO i NEED TO FIT AN ADAPTOR AT ONE END TO TAKE 15MM TO 1/2 INCH OR 15MM TO 3/4 INCH?
Any advice is very welcome.
Pete
1.
2.
3.
Pete
