fitting built in oven
10 Feb 2011
Lanarkshire
hi long time reader, first time post !
my build in single oven packed in and i am in the process of buying a replacement but am now paranoid regarding the ventilation requirments.
the measurements of my space are;
height 670 mm
width 570 mm
depth 570 mm
are these measurements what i should be comparing to the "recess measurements" ?
and the oven i am looking at measurements are;
590 x 560 x 550mm
now obviously this only leaves circa 20mm space at the back when most manufacturers suggest 45 mm.
The oven sits on a shelf basically, but it it is a good 5-7mm shorter than the oven itself, does this help with ventilation ?
thanks very much for your help.
