I'm having my gas meter moved and want to fit a built-in meter cabinet that fits into the cavity wall.
The small problem that i can see is that the cavity is filled with millions of little balls of stuff (injected cavity wall insulation).
I can envisage an avalanche of the little devils when we cut the aperture for the cabinet.
Are there any tips for cutting out the big hole while getting the insulation to stay put? I had thought about drilling a few holes around the perimeter and squirting expanding foam in. Your advice would be most appreciated!
