So, The boss has decided an electric shower is needed in the bathroom. I have suggested a mixer will be cheaper and easier but that doesnt fit in with her plans so electric it is.
I havent been in the UK for a long while and everyone is talking about Part P for such an installation. From what I gather, I need to inform someone (Who?) what I want to do, do the work, then get it inspected (who again, and how much?)
Thing is....a few people have told me that these laws arent applicable to Scotland yet. Is this true?
The plan is as follows..any tips or suggestions would be appreciated.
Typically the bathroom is at the opposite corner of the house to the consumer unit, but as the rest of the house is scheduled for redecoration I will be able to conceal the wiring ok.
From the shower location, I will be using 10mm cable, fitted into a vertical groove in the wall (to be tiled over). Under the bath, (p-clips on the floor) and through the bathroom wall. Vertically up inside the wall to a shower switch outside the door. From there horizontally in the walls. Fortunately, all walls concerned and plaster partition walls so fitting the cable in a groove cut into the plaster will be easy. The cable will be p-clipped at each wooden support.
All the way round to the hall cupboard where the consumer unit is.
Now, the existing unit has no spare capacity so the plan is thus....the wee wire security seal thing has been missing off the main fuse in the supply to the house, allowing the entire installation to be disconnected. Its always been like this since she moved in. I plan to cut the wires between the meter and the old consumer unit, and using suitibly rated junction boxes, join in new wires to a secondary consumer unit with RCD and mcb specifically for the shower, also giving a bit of spare capacity for future work. The earthing will be joined to the existing earth contact next to the old consumer unit.
Any flaws with the plan?
I assume this would come under the part-p regulations (if they exist in scotland) if so should I leave the walls unplastered untill its all been expected?
Any other tips?
Thanks.
Any other tips?
Thanks.
