I'm learning how to replace/fit an external door and frame myself (I begrudge paying the £150 quoted by a joiner) as the original in the side of my garage is rotting away.
I've bought all the correct ingredients - door, frame, 5 lever mortice, hinges, handles, wood preservative...
I wouldn't be able to do it all in one day (or week!) so before removing the original door.... I've assembled the frame, measured and chiselled out the recesses for hinges (both door and frame), drilled out the area for the lock (on both door and frame), everything fits together wonderfully... except the door does not sit flush against the frame on the hinge side...
Can someone please provide advice. Is it simply a case of recess the hinge pin area (whatever its called) and drill more holes in the frame or what?
Advice greatly appreciated.
