Sorry for the misunderstanding and i appreciate the concerns over safety, i so want to live. Unfortunately i've mislayed the Manrose instructions but trying to follow their guidelines from website but as explained came unstuck regards isolator switch connections and don't want to get it wrong. The Marbo Excel fan isolator lists two diagrams, fan isolator without timer lists twin & earth cable from junction box to L1-L3, earth and switch live and neutral from L1,L3 to fan and diagram with timer lists 3 core & earth cable to L1,L2,L3, earth and switch live L1, permanent live L2, neutral L3 to fan. The fan is a humidity with adjustable timer version and uses two core neutral and live flex, no earth required. This is where i got lost, how can i connect as per diagram of fan isolator with timer when the flex only contains permanent live & neutral !. The fan does have connections for N, SL, & L.
