I've been having problems with a Torbeck bottom fill valve not shutting off. Have replaced the diaphram a few times but it doesn't fix the problem for long. It's also recently been hammering when it does shut off after filling.
So now I'm thinking of replacing the Torbeck with a Fluidmaster PRO45B (with brass shank). I'm a complete amateur so I will probably get a plumber to come and do the work, but I first wanted to get some advice on whether or not the Fluidmaster is the right thing to get, and if it will be possible to fit one into my tank, which has a very large flush valve close to the inlet valve ? I'm attaching photos ...
Thanks in advance for any suggestions ...
Earl
PS - I've been told that replacing the whole valve can be tricky on a toilet like mine where the porcelain tank sits directly on top of the porcelain bowl - why is this & how to best avoid causing damage ?
View media item 55413View media item 55412View media item 55414
Earl
