I thought I was saving myself some money by buying a cheap bath from the internet.
When it arrived I have found that it has no wooden frame around the top of the bath lip. Is this usual, or just cheap?
I now need to build a frame so I can sucure it.
What is the best way of doing this? I was thinking of siliconing a wooden frame onto the underside of the top of the bath.
Also I have to drill the centre bath tap holes, I was going to use a 30mm hole saw, or should I use a tighter 1" cutter and file it out? I was going to put wood under where the taps are to make it more ridged as well.
Sometimes cheap is not always best.
