Hi the mrs just got a new gas cooker today i (stupidly) disconnected the old cooker now on attempting to connect the new cooker there is a SMALL gas leak from the flexible pipe connector (checked with washing up liquid just a few small bubbles) i disconnected the pipe totally from the bayonet/cooker fittings.
I presume you need some kind of thread seal to apply to the fitting? And am i right in saying that i can carry out this work myself AS LONG AS IT IS CERTIFIED/CHECKED by a Corgi registered fitter? The mrs has been quoted a silly(by my standard) £100 just to connect this cooker!! (the cooker was only slightly more to BUY!!
I heard that you can call out the "gas man" after you do the work and he will run a gas safety test and issue a certificate. Or is that just a myth?
Thanx.
Thanx.
