Just wanted to post a quick status on this since I couldn't find anything while googling. Basically, what happened was that I bought IKEA's smart bulbs with GU10 sockets, only to discover that they didn't fit in my ceiling socket even though they looked very alike.
After discovering this earlier thread about GU10 and L1 sockets I realized that they are essentially the same socket, but that there is a small plastic pig that should prevent you from inserting an older bulb, i.e. a non-low-energy bulb into the socket.
The problem is that there seems to be only one company doing these bulbs, even though there are plenty of other companies that makes low energy lightning. In my case, I wanted to replace a 15 watt bulb with a 6 watt one.
I tried to find any workaround online but didn't find anything, I guess that these sockets aren't that common yet... Anyhow, I figured that I should just be able to cut down the small plastic pig in the socket, and everything should work. I used a small nail clipper, which worked great.
tl;dr trim the small plastic pig in the socket and you should be able to fit a GU10 bulb into an L1 socket
