I've just built a new garden gate and decided to fit Hook and Band hinges. When I slide the hook into the band there seems to be between 2 and 3mm movement of the hook pin inside the hole in the band.
If I fit the band along the centreline of the top and bottom rails of the gate and the hook plates vertically on the post, won't the gate drop because of the clearance?
Should I try and fit the hook plate slightly off vertical to try to compensate for this?
This is the first time I've hung a gate so maybe I'm over thinking it !!!
This is picture illustrates the effect of the excess clearance of the hole in the band with the hook plate lined up against edge of the gate
Regards
Steve
Regards
Steve
